Power of Inverter FR-F700
Old Dec 7, 2005 | 05:37 AM
BenGan's Avatar
Default Power of Inverter FR-F700
Hi everyone!
I going use Inverter for drive pump motor of power 90kW.
In the Mitsubishi short description letter write down that the model FR-F740-01800 drive motor rated capacity 90 kW at 120% overload capacity.
May I use this model of Inverter for drive motor 90 kW?
Old Dec 7, 2005 | 04:02 PM
Sanguinius's Avatar
Default RE: Power of Inverter FR-F700
Just going by the #'s you put up in the post I'd say you CAN use it BUT you'll be pushing it to the limit. The 120% is meant for a protection buffer in case of a spike. Running it at the high limit like that will probably cause it to wear out quicker. I'd recommend trying to find a bit higher of a rating just to save the hassle and the $ of constant replacement. That's just my thoughts on the whole idea.
azchipka
Aug 25, 2014 04:25 PM
tareks
Jul 11, 2009 04:12 PM
p6793026
Sep 23, 2008 02:38 AM
3000gt1999
Jan 11, 2007 09:12 PM
tunit7
Jul 19, 2005 08:09 PM
