prime oil pump
Old Apr 22, 2008 | 10:57 AM
hiflyen's Avatar
Default prime oil pump
I have seen how to prime the oil pump on a 1G. I have a 420A and just rebuilt it. So how do I get the oil pumping through the engine again?
Old Apr 22, 2008 | 02:55 PM
dsm1990gsx's Avatar
Default RE: prime oil pump
Well if you took apart the oil pump you could just use vaseline between the gears. Also before you start it for the first time after a rebuild disable the fuel pump and crank it untill you build up oil pressure.
MNalfa
17
May 9, 2019 06:07 AM
jsawyer
Apr 13, 2008 06:51 PM
50ul }{4ck3r
May 1, 2007 08:05 PM
montero91help
Nov 28, 2004 11:48 PM
thunderman
Oct 14, 2004 07:33 AM
