trying to put oil pump assembly
Old Oct 14, 2004 | 07:33 AM
thunderman's Avatar
Default trying to put oil pump assembly
hi peeps
i m fixing for the dodge caravan 2.6 mitsubishi motor ......and im stuck with oil pump assembly because tensionner is making me hell to install.... while timing chain is there ......i have to remove timing chain to make oil pump more easier to install ? then what is the procedure ? the manual i have is su** anyways the timing chain is very black i cant check plated link for lining up with gears and chain mating mark .... if i remove timing chain .... i will lose plated link for the chain ....
anyways it is my first post
USER_22
Jan 9, 2021 08:54 PM
MNalfa
17
May 9, 2019 06:07 AM
maggiesmim
May 18, 2015 09:02 AM
Logcabin1
Oct 20, 2014 07:58 AM
98TSi awd
Feb 9, 2009 12:13 PM
