Fuel Pump Assembly Unit
Old Mar 1, 2007 | 10:50 AM
USER_22's Avatar
Default Fuel Pump Assembly Unit
I was cleaning out my car and the little inside compartments and stuff inside the carand I took a look at inside my fuel pump panel and I notice that the high pressure line is some how rusted, whats the best way to remove the rust or possibly getting a new fuel pump assembly holder thing. I dont want it to break or crack or anything.
Old Mar 1, 2007 | 11:25 AM
thestealth's Avatar
Default RE: Fuel Pump Assembly Unit
They get rusty from being exposed to the elements. Probably just surface rust. Lightly sand it with some fine sandpaper and either paint it or spray it down with WD40 or something once in awhile if it really bothers you.
This is pretty normal though.
Old Mar 1, 2007 | 11:42 AM
USER_22's Avatar
What if it cracks, is their a way to buy another one, or whats the best wayto repair it?
Old Mar 1, 2007 | 12:15 PM
thestealth's Avatar
Damn dude, you worry about the strangest stuff.
You can probably purchase a new line from the dealer, but seriously, it's not something that you need be worrying about...unless it is starting to leak...is it?
Old Mar 1, 2007 | 04:47 PM
USER_22's Avatar
Nah its not leaking but im just trying to make sure everything is covered.
Old Mar 1, 2007 | 05:11 PM
thestealth's Avatar
As long as it is just surface rust and not flaking off in chunks, it will be fine.
Old Dec 18, 2019 | 09:29 AM
Kprof's Avatar
kprof is doing this replacement as a result of said rust i found parts on west coast used and reliable sources
i will share what I can
Old Jan 9, 2021 | 08:54 PM
Robert McPherson's Avatar
Gt fuel pump can be expesive, make sure you use a lot of penitrating oil. CSX in Concord,NC has replacement pump assemblies in stock.
Mac
MNalfa
17
May 9, 2019 06:07 AM
maggiesmim
Jun 3, 2015 07:27 AM
maggiesmim
May 18, 2015 09:02 AM
Logcabin1
Oct 20, 2014 07:58 AM
98TSi awd
Feb 9, 2009 12:13 PM
