rattle noise on front end
Old Aug 25, 2009 | 07:02 PM
dj_jerry_p's Avatar
Default rattle noise on front end
I have a 2004 mitsu ralliart, lately when you start going and hit the clutch to shift some rattles very hard on the front... i try replacing the sway bar end links but still does it, now im going to try replacing the bushings of the sway bar to see if it is..also when you drive on bumby roads you can hear it too...i checked the whole muffler from manifold to pipe and is all good,,, what can it be.....any suggestions???? Thank You
Old Aug 26, 2009 | 10:57 AM
jason clipse's Avatar
i would look around in the suspension to see if u can find any rubber pieces that broken cracked worn or anything. if not the suspension, u said it happens when u push the clutch in, try revving the engine in neutral and in gear with the clutch pushed in and see if there is a difference.
Old Aug 26, 2009 | 11:25 AM
trying to help you with noises over the internet is next to impossible. All i can tell you is try and figure out which side its comming from and then start looking around. But is the sound metal on metal? Is it something that could be a blown strut? Or is it just more like something is loose?
Old Aug 26, 2009 | 01:01 PM
i would have to agree with this statement.
innieoroutie
Mar 14, 2015 08:09 PM
tomwalshco
Nov 24, 2014 04:28 PM
Russk1978
Nov 23, 2010 11:45 AM
Subydrift
Mar 10, 2009 09:47 AM
jkrusa
Dec 19, 2004 09:29 AM
