Re : 3000GT Suspension
Old Oct 7, 2005 | 01:06 PM
Traser's Avatar
Default Re : 3000GT Suspension
Hi,
New to the forum, I have a '93 3000GT Twin Turbo. Not sure if it is the suspension but was looking for some advice. When driving the steering is all over the place, it wanders all over the road and follows the slightest camber. Can be real hard work to keep it in a straight line. One of the front shocks is leaking slightly so I thought that this was maybe the problem or a bush ??? Any advice would be greatly appreciated.
Cheers
Matt
Old Oct 7, 2005 | 05:54 PM
FireDoc's Avatar
Default RE: Re : 3000GT Suspension
Sounds like a tierod end to me. I am not a know-it-all for steering systems though.
Old Oct 7, 2005 | 06:45 PM
TheAdvocate's Avatar
Could be soemthing with your shocks.. But also could be just needing an alignment or the tierod like firedoc said...
Old Oct 12, 2005 | 04:30 AM
twinstealthytalon's Avatar
It could be anything that is related to your steering/motion across the roadways.
I would put the vr4 on a lift in the garage, and check to see if there is any play by grabbing your tire(s) and do a side to side check, and then up/down check... if that makes any sense?! You should be able to tell right away after grabbing each tire agressively.
It might just be the fact that we have all wheel drive cars, with low profile tires, and on a roadway with grooves worn into it, "god damn!!!"
I avoid certain roads by my location because of that... side to side uncontrollably.
Do you have a constant problem with this? or once and a while? or ???
[IMG]local://upfiles/5323/F8A7A5E8241E44458E89AE8C22F3CC16.jpg[/IMG]
xi8883
Oct 4, 2010 09:13 AM
MikeMac
Sep 19, 2007 11:25 AM
enzo_hashmat2006
Aug 16, 2005 06:43 PM
Galantz01
Feb 19, 2005 04:43 AM
jacek
Jun 16, 2004 07:02 PM
