runs rough on idle when cold
Old Mar 26, 2006 | 03:19 PM
quadblaster94's Avatar
Default runs rough on idle when cold
whats up guys i got a 2000 eclipse that runs rough on idle and when in gear at a stop but goes away once i drive for about 10 minutes. anyone experience this?
Old Mar 27, 2006 | 09:13 PM
99clipsgst's Avatar
Default RE: runs rough on idle when cold
is it smoking any? and what does the temp guage read while it is running rough?
Old Mar 27, 2006 | 09:16 PM
well he said it is when the car is just started and for the first ten minutes or something so i am going to guess cold on the temp. I would check with emonz on here cuz he has alot of experience with 3g problems
Old Mar 30, 2006 | 03:01 PM
mysterio2099's Avatar
My car did something similar to this during the cold season.. It's slowing down now that we're going into spring. Even after the car has warmed up, during an idle state the car with sputter and the therm. will go about 1/2 way up. If I give it just a tad bit of gas the problem goes away. Also, my car has had some white smoke out of the pipe since I got it in November 2005.
Not sure if this is the same problem quad is having. I have a 2G as well, not a 3G.
Old Jan 31, 2007 | 12:27 AM
marquesalan's Avatar
I have the same problem. Had my motor mounts changed, the throttle body cleaned, new wires and spark plugs and my fuel injectors clean. It shakes when I am idle with the break on and when I go in reverse.
I was told by the dealership that it could be the transmission mount! How many mounts does this car have and why do they go bad!
Galanthighspeeder
Apr 30, 2012 05:01 PM
coolcloo
Apr 25, 2011 01:25 AM
jyounadim
Nov 24, 2008 02:43 PM
outlancer
Dec 11, 2004 09:36 PM
Salazar
Oct 4, 2003 09:36 PM
