Several problems
Old Feb 22, 2010 | 09:46 PM
99gsexy's Avatar
Default Several problems
Hello everyone,
I have a few problems that I hope someone can help me with. I have a 1999 Mitsu Eclipse GSX.
1. Blackish smoke coming out of the exhaust after a while of idling + a slow oil leak under engine = Bad head gasket?
2. My ABS AntiLock Light came on at the same time my car started to overheat. The light will turn off randomly and when it does the temp gauge seems to drop to normal, but creeps back up and the ABS light comes back on. Any thoughts?
3. Got a new alternator + battery a few months ago, but the car idles low and usually the battery light is on when I start up the car, then goes away after reving the engine. Electrical problem?
Any help that you guys can provide would be greatly appreciated.
Thanks
Old Feb 24, 2010 | 07:42 AM
1. blackish smoke coming out of the exhaust after a while of idling + a slow oil leak under engine = Bad head gasket?
burning oil. Probably bad valve stem seals.
are you sure its the ABS. Because overheating and abs are totally different.
Check the battery terminals for corrosion
Old Feb 24, 2010 | 03:49 PM
99gsexy's Avatar
Thank you for the reply.
ABS is probably different, it might have been a coincidence. I felt the pressure of the radiator hose and it was hard, so i'm thinking its my thermostat. I got a new one and i'll throw it on tomorrow.
As for my battery terminals, you are right they are corroded. Should I replace them, or is there another underlying problem?
Thank you again.
Old Feb 24, 2010 | 04:20 PM
i would just replace them. You can get new terminals cheap at autozone.
Old Feb 27, 2010 | 02:33 AM
99gsexy's Avatar
Okay, swapped out the thermostat... Still overheating. I did notice that when I have the vent air on, both fans kick on periodically, which bring the temperature down to normal. The fans won't kick on until the vent is on. Any suggestions?
Old Feb 27, 2010 | 08:45 AM
dsm1990gsx's Avatar
Sounds like a bad fan switch, mine went bad on my 1g and in stop an go traffic it would overheat a bit.
Old Mar 4, 2010 | 10:08 PM
MitsMaster's Avatar
There is a sensor in the bottom tank of the radiator. It has two wires. When the temp guage is above normal unplug the radiator sensor a jump the two wires together, the fans should turn on. If they come on replace the sensor. If they dont, unplug the fan harness connectors and look for melting or heat damage in the connectors. If that is fine you may need to check the relay.
Sean Backus
Jun 18, 2013 11:03 AM
foetusenvy
Feb 5, 2008 11:53 AM
Addikted2wips
Nov 23, 2007 07:05 PM
Addikted2wips
Sep 7, 2007 04:13 PM
