slave cylinder problems
Old Feb 2, 2006 | 11:58 AM
antomx's Avatar
Default slave cylinder problems
My eclipse has the ACT 2600 lb. pressure plate and I've also replaced the clutch line and reservoir down by the tranny with a stainless steel line. I just put a new slave cylinder on because the old one was leaking. After bleeding it and taking it around the block a few times the clutch started going soft and I had to pump it up to shift. Needs more bleeding right? So I bled and bled and bled, driving the car in between, all with the same result: Soft pedal not staying pumped up. I didnt really see any noticable leaking and why should I, its a new slave cylinder. So I pop the rubber boot off the NEW slave cyl. and fluid poured out......it was leaking! Has any one else had any problems like this? I'm hoping I just got a bad slave and its not the ACT pressure plate and bigger clutch line that is putting more fluid pressure through than a factory slave can handle.
Old Feb 3, 2006 | 10:36 AM
antomx's Avatar
Default RE: slave cylinder problems
Looks like it was just a bad slave. I got another one and its fine but now it seems like my master is going out.....oh well...........Got one coming today.
Old Feb 3, 2006 | 10:49 AM
Street Surgeon's Avatar
Yeah, I've heard those non-oem type replacements can be crummy sometimes but I've never personally had a problem with em. Good call.
kevinc
Mar 10, 2012 05:02 PM
Natedogg89
Sep 18, 2007 10:07 PM
jerusry
Oct 15, 2006 04:15 AM
EveIsle
Sep 13, 2006 10:03 PM
micahman
Mar 3, 2006 10:52 PM
