sputtering
Old Sep 26, 2005 | 10:57 AM
90galant's Avatar
Default sputtering
ok i just bought this 1990 galant (single overhead cam) dont really know much about it ecept that is is really clean but anyways.............my car is kinda like sputtering when its ideling and if you dont give it at least half the gas peddle (while driving) then it wants to like pull aginst its self if you know what i mean please help this car is bad ***
Old Sep 26, 2005 | 01:54 PM
DSMTalonAWD51's Avatar
Default RE: sputtering
check for vacuum leaks and check the idle asjust screw
Old Sep 26, 2005 | 06:36 PM
Patrick's Avatar
Administrator
i had a crack in the pipe leading from my MAFS to my TB and it was getting unmetered air, causing the same condition.
Old Sep 27, 2005 | 02:02 PM
90galant's Avatar
ok ill check all of those things and hopefully it will run better ill let you kno how it works out and thanks for the help ........
Old Sep 27, 2005 | 10:20 PM
TheAdvocate's Avatar
I had the same thing before my motor went on me with my eclipse... Is the check engine light on? If so take it in right away... But otherwise it could be something to do with the fuel pump or the injectors... That can be so many things... the Idle speed might need to be adjusted too... Could be something simple and inexpensive... [:-]
Old Sep 29, 2005 | 03:05 AM
90galant's Avatar
The check engine light is only on when you first start the car up for like 10-15 seconds then it goes off and wont come back on.... some one also told me that the ignition timming might be off a little bit to could that cause this to happen?
Old Sep 29, 2005 | 03:17 PM
I dont think that would have anything to do with it... I could be wrong tho.. If your check engine light doesnt stay on then there wont be any codes that are getting tripped...
bobbytomforde
Dec 24, 2005 12:38 PM
1997gsteclipse
Dec 8, 2005 03:10 PM
eclipse27
Dec 6, 2005 03:24 PM
WGONFAN
May 4, 2005 05:40 PM
girlgetter
Jun 23, 2004 08:05 PM
