Starter Problem - 2001 Eclipse
Old Apr 19, 2008 | 11:10 AM
bxm859's Avatar
Default Starter Problem - 2001 Eclipse
Have a 2001 Eclipse, 6 cyl, manual. Starter does nothing with turning key. Pulled the starter and it works fine. Problem started as intermitent. Now nothing. Car jumps fine on hill. Appears key is not powering solonoid. any suggestions on relays or methods of tracing fault. Looked at ignition fuses and they're good. I know the clutch has a switch and probably one on the neutral position. I cna be contacted directly at bxm859@yahoo.com . Thank for any and all assistance. Bill
Old Apr 21, 2008 | 03:33 PM
dsm1990gsx's Avatar
Default RE: Starter Problem - 2001 Eclipse
Well if you have no power at the solenoid, check the starter relay and see if you have power in start there.
toddyfresh
Dec 26, 2006 01:18 AM
lucidity6425
Sep 26, 2006 07:54 PM
19eclipse91
Aug 26, 2006 03:56 PM
importeclipse18
Jan 23, 2006 09:10 PM
