Starter problem
Old Nov 13, 2007 | 11:11 PM
Azazel's Avatar
Default Starter problem
Hi,
I have a 2G Spyder GS. The thread on one of the bolts that holds the starter in place has smoothed out so the starter vibrated loose. We re-fastened it tonight but the mechanic told me that I would need to have a permanent fix done ASAP.
He said that the starter is fine, but that I'll need to replace it anyway because the threads that fasten it are attached and can't be purchased separately. I'm just trying to find out if this is BS, or if not, how much it will cost me for a starter. I went to the site I usually price parts with, rockauto.com, but couldn't find "starter" anywhere so I thought I'd ask here.
Thanks...
Old Nov 14, 2007 | 06:56 PM
dsm1990gsx's Avatar
Default RE: Starter problem
Do u mean the bolts that hold the starter stripped out? Try using a tap and die set and see if you cant try and clean the threads out?
Old Nov 14, 2007 | 07:11 PM
jpmontero98's Avatar
what he said plus buy additional bolts or screws to hold it good
Old Nov 15, 2007 | 12:39 PM
Azazel's Avatar
OK, thanks.
Old Nov 23, 2007 | 02:31 PM
smokinu6's Avatar
use duramix from napa. fill the hole with it use new bolt put it in wait for it to dry and wrench it out. it'll make new threads and be fine it dries in less than 1 min.
Mike Kelley
Feb 1, 2008 09:56 PM
adinator
Jul 1, 2007 01:44 PM
toddyfresh
Dec 26, 2006 01:18 AM
19eclipse91
Aug 26, 2006 03:56 PM
importeclipse18
Jan 23, 2006 09:10 PM
