starting problems 2002 Lancer
Old Nov 21, 2008 | 04:38 PM
zard4life's Avatar
Default starting problems 2002 Lancer
About one month ago Sept08, my 2002 Lancer suddenly did not start; I have owned the car since day one.
The battery was replaced, a new alternator put in, and finally a new starter. The same issue still is present.
When the key is in the ignition and I turn with the clutch pedal down, nothing happens-no crank, but there is some power. But not enough to lock the doors. The radio shorts out and all the programmed stations are wiped out, but the clock is not reset.
Sometimes the car will start, sometimes it wont. The only other item I have messed with is under the hood is the green ECU that was clicking loudly before the battery was replaced. I unplugged it and replugged it to make it stop clicking.
Any ideas?
welshgit
May 22, 2015 05:08 PM
bluey73
Jan 5, 2013 11:39 PM
jp2000
Jan 1, 2012 05:21 PM
kimbok
Sep 29, 2008 02:54 AM
ruslancer
Mar 5, 2005 02:59 PM
