Sunroof
Old Mar 12, 2005 | 01:43 AM
PistolPete's Avatar
Default Sunroof
Hi. I am having difficulty with my electric sunroof. The motor sounds like it is working but the window won't open. I think the cable might be broken or snapped. If you know how to get it open to have a look or any other tips send them my way. I drive a 1992 Pajero GLS. Ta!
Old Mar 12, 2005 | 05:24 AM
DSMTalonAWD51's Avatar
Default RE: Sunroof
try taking the glass piece out and then observe the arms that move the sunroof on each side. I had the same problem and it turned out that on one side the arm got disaligned. its kinda hard to explain but if u take the glass out and see anything that looks wrong it will be obvious and it fixed the problem.
Old Mar 12, 2005 | 05:50 AM
PistolPete's Avatar
Default RE: Sunroof
thanks for the help,does the glass part just unscrew and lift out any more help on this would be much appreciated.thanks again
Old Mar 13, 2005 | 05:14 AM
DragonRacerX666's Avatar
Default RE: Sunroof
Just try to push the button the same time as trying to push up on the sunroof...
I had a 94 civic and it got stuck so i did that and hit it kinda hard with my hand and it worked ever since.
Old Mar 13, 2005 | 10:48 PM
Default RE: Sunroof
hitting it is what you DONT want to do. there are sensivitve parts up there and you can easily break something. pushing on it a little while holding down the button to give it a boost might help, but dont hit it. To take it off,yes there are just screws on each side inside the car
jthorn75
Jun 4, 2012 04:18 PM
MrJayDeeOne
Aug 23, 2007 03:58 AM
Kdani
Sep 26, 2004 07:19 PM
iceyman
Nov 2, 2003 06:26 PM
tjrcs
Oct 7, 2003 04:28 AM
