temp rise uphill
Old Apr 27, 2014 | 01:38 PM
jetblack's Avatar
Default temp rise uphill
hello, got a 54 reg l200, turbo diesel, 2500, had a new head on 8k miles ago, at the dealers, just lately when i go uphill, fast , slow, steady away, the temp guage goes up to about three quaters, then after the hill it comes back down to normal, put a new thermostat in but thats all soo far. can anyone suggest any thing. the dealer just said it wont be the head ! everything else is ok, apart from temp rise. theres 98k on the clock.
Old Apr 27, 2014 | 03:09 PM
Could be a head gasket, or an air bubble in the cooling system.
You can rent a tester that hooks onto your radiator where the cap screws on, and you run the car and it'll tell you if your head gasket is leaking.
The fact that you're having trouble under load leads me to believe a blown head gasket. If you don't want to rent the tester then just let the car idle with the radiator cap off, and watch when the thermostat opens. If you see a crap load of bubbles, then you know you've got a head gasket failure. If you have no bubbles after the thermostat opens, then rev it up a little and see if that creates any. There should be NO bubbles.
Old Apr 27, 2014 | 06:51 PM
mxmikie's Avatar
could be a plugged radiator or a bad fan clutch
Old Apr 27, 2014 | 08:44 PM
Good call!
Old May 13, 2014 | 01:23 PM
2001Mitch3.5XS's Avatar
Remove your radiator cap and look at the inside...check for oil dep...Head gasket or Head itself. Smell it what does it smell like. There shouldn't be any oil deposits on it at all. Look at the filler bottle is there oil deposits in it.....
noob
Sep 2, 2012 11:20 AM
sevendogzero
Mar 20, 2012 01:46 PM
chili_g
Apr 27, 2008 08:48 PM
X Treme
Jul 22, 2007 08:30 PM
matt02708
Feb 16, 2007 04:59 PM
