TPS Voltage
Old Dec 18, 2005 | 01:54 PM
MyLittleBlackBird's Avatar
Default TPS Voltage
What's the no throttle and WOT voltage readings for TPS supposed to come out to key on engine off? Thanks!
89 mitsi galant 2.0 SOHC
Old Dec 20, 2005 | 12:16 AM
Joel_CA's Avatar
Default RE: TPS Voltage
There are no WOT TPS specs- only closed throttle. Generally, it should be between 400-1000mv with the CTS ON. Once its set to closed throttle specs- it should sweep evenly from closed throttle to WOT without any dips or spikes in voltage. Good Luck!
Joel, CA
NGC1672
Mar 30, 2010 07:11 PM
agood1
11
Feb 18, 2007 02:20 AM
TheAdvocate
Dec 7, 2005 08:30 PM
spc_76
Jul 1, 2005 10:59 AM
wicked_outlander
Apr 4, 2005 10:05 PM
