tranny swap
Old Sep 26, 2008 | 05:51 PM
94eclipse47834's Avatar
Default tranny swap
i just purchased a 94 eclipse 1.8 it used to have a auto tranny in they converted it to a manual tranny they have spliced some wires and removed a wire from the fuel control relay i can get it to start and run but it acts flooded at first but then clears up also the fuel pump dosent come on when i turn the key to on has any one done a swap like this is there a kit or something so i can sort out the wiring please help
Old Sep 26, 2008 | 06:52 PM
silvercoupe97's Avatar
Default RE: tranny swap
The car runs like that at the beginning because the fuel lines aren't fully pressurized. The fuel relay should only have 4 wires connected to it. The fuel pump may or may not turn on until the starter kicks in.
You may want to check the fuel filter, it can be ready to change that out.
Unless you like a cheap version of the autostick, I would have that "option" removed because the tranny isn't made to work like that. Those auto trannies build up a lot of heat.
So, what about a tranny swap?
Clipse1
Jan 19, 2007 01:37 AM
X_defiance
Aug 23, 2005 10:17 PM
enfuegodp
Aug 9, 2005 11:30 PM
andauto
Feb 25, 2005 02:18 AM
MiataDooU
Nov 19, 2003 03:27 AM
