Transmission
Old Dec 5, 2015 | 09:08 PM
Ava7Mekhi's Avatar
Default Transmission
Hi guys my 2012 outlanders alarm for transmission fluid too hot keeps coming on while towing . Can't seem to get an answer . Has anyone else had this problem
Thanks heaps for any help
Old Dec 5, 2015 | 10:00 PM
The Silent Seed's Avatar
Without any information, I can only assume you're indeed pushing it.
Old Dec 5, 2015 | 10:48 PM
Ava7Mekhi's Avatar
Thanks for your reply . It towes my trailer very easy . The warning light comes on after 70 km of towing . Telling me to slow down fluid in transmission is hot . 5km before light comes on a whizzing sound can be heard
Old Dec 5, 2015 | 10:50 PM
How heavy is the trailer when you're towing? Which engine are you using? The usual 2.4L is only rated for 1,500 pounds capacity. Sorry I'm not more help. Is it more often when the going gets hilly?
Like I mentioned, it's hard to have a starting point without any information.
Old Dec 6, 2015 | 01:04 AM
Ava7Mekhi's Avatar
Trailer is 1200 kg so it tows to 1600 kg no doesn't matter if it's flat road or hilly same happens . Could the trans belts maybe be slipping when put under extra stress . Cheers
Old Dec 6, 2015 | 08:22 AM
So, you are towing 3,500 pounds, which is a full ton over the 2.4L towing capacity?
This is not adding up - and you are not giving us information to help you - Good luck.
glennsafrit
Oct 25, 2004 12:29 PM
khscott
Aug 15, 2004 02:38 AM
LESLEY
Jul 19, 2004 08:35 PM
stbmotors
Jul 10, 2004 05:29 AM
