Will a 2g 4g63t work in a 91' VR4 ?
Old Mar 9, 2005 | 08:39 PM
Daz's Avatar
Daz
Default Will a 2g 4g63t work in a 91' VR4 ?
I bought a 2g 4g63t for my 91' Galant VR4 , but I'm not sure if it will fit cause its a 7 bolt . Does anyone know if it'll work ? At least the block !
Old Mar 9, 2005 | 09:57 PM
dsm king's Avatar
Default RE: Will a 2g 4g63t work in a 91' VR4 ?
It should fit because people put 6 bolts in 2g's all the time. You should have bought a 6 bolt block, but thats ok. The only problemI can think of right now are the splines of the driveshaft and the splines of your transfer case. I dont think those would match up.
Old Mar 9, 2005 | 09:59 PM
dsm king's Avatar
And just the block alone wont fit because your galant has a 6 bolt transmission, that will not bolt up to a 7 bolt block. So youd have to use a 7 bolt tranny.
Old Mar 9, 2005 | 10:14 PM
Daz's Avatar
Daz
Cool ! Thanks for the info ! But I was told that the 6 bolt crank won't fit cause the position of the bearing are different then the 7 bolt.
Old Mar 9, 2005 | 10:44 PM
dsm king's Avatar
The bearing? The crank angle sensor wont work either. so the only thing you could do is get a 7 bolt tranny, or get a 6 bolt block. Are you fully building a motor?
Old Mar 9, 2005 | 10:58 PM
dsm king's Avatar
Well now that I think about it, there arent any splines on the driveshaft, its just a slip yoke, I THINK. Anyways i dont see any problems with this swap. Ill look into this and get back to you, cause Im very interested to see if this would work without any major modification.
Old Mar 10, 2005 | 12:41 AM
Daz's Avatar
Daz
Hey ! I really appreciate it and I'll keep you posted . I just need something to get me back on the road for now while I build the original so I can keep everything stock if I wanted to . If the only thing is the crank and if it still works then I won't have to sell this engine . When I get back into town on the 19th , I'll tear into it !
Old Mar 14, 2005 | 02:10 PM
Daz's Avatar
Daz
I decided to sell the engine I bought and get the engine the fits correctly in the car ! Are you in Kali ?
Old Mar 14, 2005 | 04:43 PM
dsm king's Avatar
Nope Denver, Co
capital 97 tsi
Mar 23, 2009 09:55 PM
3000gtman
Mar 25, 2007 05:28 PM
toneloksta
Sep 8, 2005 05:06 AM
Daz
Mar 9, 2005 05:35 AM
xblade
Nov 20, 2004 11:54 AM
