04 lancer es 2.0 heat problem
Old Jan 8, 2014 | 07:13 PM
Charles Shaheen's Avatar
Default 04 lancer es 2.0 heat problem
ok when I first bought my car the heat was great no problems now I have problems. When I start the car in the mornings I let it run around 15-20 mins the engine is well heated but yet I don't have very good heat coming from vents but when I accelerate to 3000 rpm then my heater will work so good to the point if u have it on high it'll burn ur face I had a new thermostat put in, flushed the entire system no clogs or anything I had the cooling system bleed only a little air pockets I'm not loosing any fluids when I take the radiator cap off the coolant is level I just don't know what else it could be please help thanx
also I just found out that if I turn the heater too full blast it stays around 60 degrees which is not hot but then I turn the heat down 1 notch it goes to 115 which is decent then I turn it full blast and rev the engine to almost 3000 rpm I get 150 degrees so something is going on not sure what though
dekood
Jan 23, 2013 05:17 PM
juice58
Dec 1, 2009 09:09 PM
angel_rae_23@yahoo.c
Nov 25, 2008 09:04 AM
funnelit
Oct 9, 2006 08:43 PM
markm
Jul 10, 2004 04:09 PM
