2002 Mortero Timing Belt
Old Dec 1, 2007 | 10:43 AM
swa737flyboy's Avatar
Default 2002 Mortero Timing Belt
My wifes Montero has 82,000 miles on it. I was told it didn't need a new timing belt until 100,000 miles. Is this true? I truelly do not trust the repair shops that seem to want to rebuild your vehicle from the frame up whenever you take it to them. Timing belts are critical and if this needs to be done then so be it, if not I prefer to wait. It is a very costlly repair. Any one with knowledge about this your advice is appreciated.
Old Dec 1, 2007 | 11:12 AM
jpmontero98's Avatar
Default RE: 2002 Mortero Timing Belt
go here
it tells ya what you need, navigate through that window on the milage range
Old Dec 1, 2007 | 01:00 PM
The timing belt is recomended to be changed at 60k. The belt is designed to only last till 100k. Anythnig near 100k and it is likely to break.
Old Dec 2, 2007 | 04:55 PM
ricanpunk's Avatar
is that for the montero alone or all mitsu's? 100k sounds like alot to me
Old Dec 2, 2007 | 11:10 PM
Its standard for every car with a timing belt.
shaystarnes
139
May 6, 2024 10:56 PM
bigblockwagon
May 27, 2012 12:54 PM
inthedark
Aug 10, 2011 03:45 PM
capricorn1
Jun 14, 2011 07:13 PM
nicojaki
Mar 28, 2008 04:55 PM
