94 3000GT Vr4 not starting. Need help!
Old May 5, 2013 | 03:16 PM
3000GTVR494's Avatar
Default 94 3000GT Vr4 not starting. Need help!
Not starting - Won't start 3000GT VR4 - YouTube
Hi, last week. I had my car running. Took it out for a test drive and when I entered the highway. My car just started slowly dying. I didn't go that fast. I went about 5 thousand rpm at the most. So after that, it didn't start up. It cranked but it didn't fully start up. We took it back to my garage and realize that one of my pipe to the intercooler has been separated. So I re-clamped it to see if it starts up, but still didn't start. Did a fuel pressure test. And it read 45 psi, which is good. Used a diagnostic tool to check to see what's wrong. But there was nothing. So as of right now, it's still not starting up. Still cranks but no start. I guess the only thing I can think of is the ecu being out of program. But I'm not quite sure about that. If anyone can help me. Please lmk. Thank you!
Old May 5, 2013 | 08:53 PM
Probably fouled up the plugs running so rich with the pipe off. Yank 'em out, clean them up, and try again.
In order to reset the ECU, just remove the negative battery terminal for 30 seconds or so with the key in the ignition in the on position.
firebuck
Feb 14, 2018 08:42 AM
troyie
Jul 28, 2012 11:31 AM
stbrian
Nov 12, 2010 10:19 AM
srunnerman
Feb 25, 2010 12:40 PM
LizziVr4
Oct 7, 2008 02:32 PM
