adjust TDC piston #1
Old Oct 14, 2004 | 07:49 AM
thunderman's Avatar
Default adjust TDC piston #1
hi peeps
i m trying to find info for adjust piston #1 TDC i need compression time ....... how do u check if TDC compression or exhaust do you check valves ? help me find the compression time and i will be happy
Old Oct 14, 2004 | 07:50 AM
thunderman's Avatar
Default RE: adjust TDC piston #1
sorry it is mitsubishi 2.6 liter dodge caravan
Old Nov 16, 2004 | 01:43 PM
Dans Talon's Avatar
Remove the spark plug then shine a flashlight through the hole and see wnen the piston tops out as you turn the crank shaft with a wrench.
It should top-out a full twice during one full 360* turn. The top-out that occurs when the distributer rotor is pointing to the #1 contact is TDC #1 piston.
DT
clips69
Jun 4, 2007 02:31 PM
clips69
Apr 3, 2007 12:46 PM
edaddik
Nov 13, 2005 08:49 PM
T.O.Talon
Apr 12, 2005 12:34 PM
rvrexpy
Jan 31, 2005 03:33 PM
