BLINKERS STUCK
Old Sep 11, 2007 | 09:55 AM
athlete1012's Avatar
Default BLINKERS STUCK
Hello Can anyone help me out? I am having trouble with my left turn signal. It was working fine I went to make a left turn and the handle click back to its original positon but the light continues to flash. When I click it to the right signal it doesn't do anything no light at all but the handle clicks. I tried changing the fuse but no luck. It still is flashing only goes off when I turn off the car. The headlight work fine and the hazards are okay as well. DO you know what may be causing this? What would it cost to repair?
Old Sep 11, 2007 | 11:02 AM
thestealth's Avatar
Default RE: BLINKERS STUCK
Sounds like the switch in the steering column is broken.
Old Sep 11, 2007 | 02:59 PM
Thanks! Is this expensive to repair?
Old Sep 11, 2007 | 03:27 PM
thestealth's Avatar
The switch is probably a dealer only item...so it might not be cheap. I haven't fooled around with steering columns in a long time...they used to be a real pain in the ***, but I don't know about newer cars.
Old Sep 11, 2007 | 08:28 PM
50ul }{4ck3r's Avatar
that happend to on my 2gen.....it is all one piece easy repair ....find one at the auto yard unscrew it.......it's just a plug and play thing....
rickymac08
Dec 9, 2024 02:21 AM
btlagunas
Mar 6, 2010 05:22 PM
SILVER
1st Generation
Sep 4, 2007 05:58 AM
SILVER
1st Generation
Sep 1, 2007 12:05 PM
sunshinee
Jan 18, 2006 06:17 PM
