CONTROL BOX IN THE GALANT RADIATOR
Old Sep 21, 2007 | 08:13 PM
bravokilo's Avatar
Default CONTROL BOX IN THE GALANT RADIATOR
PLS. HELP. CAN ANYONE ENLIGHTEN ME ON THE 2-1/2 SQUARE BOX RIGHT IN FRONT OF THE MAIN FAN (AT THE BACK OF THE FAN ACTUALLY). THE TWO FAN MOTORS ARE CONNECTED TO THIS BOX AND THE BOX HAS THREE INPUT WIRES. THICK BLACK AND THICK BLUE. THEN A SMALL BLUE WITH WHITE STRIPES. CONNECTING 12V TO THE BLACK AND BLUE TURNS BOTH FANS. IF ANYONE HAS THE WIRING DIAGRAM. THE RADIATOR IS 29 INCHES WIDE AND ABOUT 17 INCHES TALL. IT HAS NO WATER SENSOR ON IT. PORTS IF ONE IS IN FRONT OF THE CAR ARE BOTH ON THE RIGHT SIDE OF THE RADIATORS.
THANK YOU GENTLEMEN.
BRAVOKILO
Old Sep 23, 2007 | 03:45 PM
Manybrews's Avatar
Default RE: CONTROL BOX IN THE GALANT RADIATOR
first, pleast stop using ALL CAPS. its annoying.
second, the box is the fan control module. it determines fan speed based on a signal from the PCM.
Randys
Aug 12, 2013 06:07 AM
westcoastryder
Apr 21, 2008 12:41 PM
maximapower
Jan 4, 2006 04:39 PM
jrk247
Apr 2, 2005 02:48 PM
