help 6g72 head replacement
Old Apr 13, 2014 | 04:24 PM
walmartlegend's Avatar
Default help 6g72 head replacement
I'm replacing the heads on my 04 eclipse gts v6 ive been searching everywhere and cant find a answer.
I was replacing the vc gaskets and i dropped a screw in the intake mani and bent cylinder number 6 valves and dents etc.
im picking up 2 heads tomarrow im looking for reassurance.
how do i know if the heads are in timing right i know the crank needs to be in compression stroke tdc1 but how do i know if the heads are matching or do i just need to have the heads timing marks lined up?
i dont want to put all together again and mess up any more valves
Old Apr 14, 2014 | 04:45 AM
Akzle's Avatar
tdc on 1 means the valves over that cyl will be at rest.
If the heads are coming with valve train and pinions fitted, the marks should be true.
Turn it over by hand a few times before hitting the starter. Put rags in holes you dont want to loose screws in.
duster6g72
Oct 17, 2012 11:08 AM
sedonamechanic
May 3, 2012 09:20 AM
raleighg34
May 15, 2010 03:02 PM
Alvin
Mar 1, 2006 02:53 PM
cooljames
Jul 19, 2005 02:54 PM
