Mitsubishi Colt 2003 EPS Probelms
Old Feb 9, 2012 | 08:42 PM
2003mitsicolt's Avatar
Default Mitsubishi Colt 2003 EPS Probelms
Hi there,
I have a 2003 Mitsubishi Colt. (4wd)
Have just recently had problems with the EPS steering.
I would start the car and the eps light would stay on.
shake the steering and it would go off.
Ok to drive and had assit.
Turn car of and start again some situation.
And now it sometimes goes of when you shake the steering other wise it just stays on.
Fault codes are:
C1531 MOTOR TERMINAL VOLTAGE
C1541 FAIL SAFE RELAY STUCK ON
C1607 ECU FAILURE.
C1541 FAIL SAFE RELAY STUCK ON - CLEARED!
C1607 ECU FAILURE - CLEARED!
C1531 MOTOR TERMINAL VOLTAGE - Stays in system
Any help would be so great!
Car looks like this
Old Feb 2, 2015 | 03:26 PM
autotechparts's Avatar
Hi, also have a colt 2005 that I am experiencing the same fault with. C1541. did you find a fix for this problem?
Old Feb 3, 2015 | 05:44 AM
2001Mitch3.5XS's Avatar
Plz keep us posted to find out how you make out here 2003
RKARNANI
May 23, 2017 05:37 AM
seeyasa
May 10, 2010 02:09 AM
brodie
Jan 8, 2008 10:58 PM
16valvecolt
Aug 25, 2005 01:45 PM
16valvecolt
Jun 1, 2005 09:24 AM
