timing
Old Dec 10, 2014 | 02:22 AM
asde33's Avatar
Default timing
2000 gallant. Broke timing belt. I replaced it & car will not ttart. Took it off turned engine 180, still no start. It sounds as if it had no spark. Checked plugs/coils OK.. Any thoughts?
Old Dec 10, 2014 | 11:53 AM
Akzle's Avatar
uhhh....
Tdc #1.
Line up your cams.
Belt on.
Check compression.
If you broke it while running, id expect a fair bit of damage.
If it has a dizzy, and no spark, id expect you sheared the drive pinion key.
Old Dec 10, 2014 | 02:33 PM
asde33's Avatar
Originally Posted by Akzle
uhhh....
Tdc #1.
Line up your cams.
Belt on.
Check compression.
Tdc yes.
All pulleys on mark, yes
Sounds like no compression, lady said it always sounded that way.
Broke while d, yes. I'll check drive pinion key-compression. Thanx
Old Dec 10, 2014 | 02:40 PM
asde33's Avatar
Originally Posted by asde33
Tdc yes.
Ooh, yes there is spark, dizzy?
Old Dec 10, 2014 | 03:52 PM
Akzle's Avatar
If theres spark then its unlikely to be dizzy issue.
Old Dec 12, 2014 | 09:29 PM
asde33's Avatar
Compression check low. Cyl 2 & 3 below 100. Took head off. Head gasket looks OK. No damage to valves or pistons. What else could cause low compression?
Old Dec 13, 2014 | 06:45 AM
Akzle's Avatar
leakdown test.
'looks ok' doesnt always mean ok.
What did the bores on 2&3 look like? Shat a ring?
Old Dec 15, 2014 | 04:04 PM
asde33's Avatar
Cyl. Smooth. If it is the rings would it show on the bore?
Old Dec 15, 2014 | 05:23 PM
2001Mitch3.5XS's Avatar
That is an interference motor .... U may have internal damage dude,..Good luck.
Old Dec 16, 2014 | 12:04 AM
Akzle's Avatar
maybe. maybe not.
that's why we do leakdown tests.
