WRX STI vs EVO revisited
Old Oct 19, 2005 | 06:28 PM
mitsusales's Avatar
Default WRX STI vs EVO revisited
just writing to say whats up and to further the debate on which is faster the WRX STI or the EVO. now i am a salesman for mitsu, but that doesn't make me bias because i'am also a huge car lover. now i sold an EVO IX MR to a guy that also has a WRX STI and Corvette ZO6, he says hands down the EVO leaves both out to dry. I personally have driven all three and there is no question in my mind which one i would take and which one i would own.................EVO IX MR......................
Old Oct 24, 2005 | 11:28 AM
Mike21's Avatar
Default RE: WRX STI vs EVO revisited
What year was the STi?? Cause I've always heard that the STi was a bit quicker that the Evo in the quarter mile but the Evo out performs the STi around the twisties. Jus bought a Evo 8 this month and I wouldn't trade it for nothing.
05 Evo VIII, Rally Red
Old Oct 25, 2005 | 05:00 PM
mitsusales's Avatar
The STi was an 2005 and the EVO IX MR was an 2006. The stock EVO IX comes in at 286hp & 290 ft/lbs of torque and reaches its max torque 2000rpm quicker than the STi or the EVO VIII, so 0-60 is around 3sec. I had a guy come in with an EVO VIII that had a serious howl to the AWD system when he was in first gear. I took around the block and I know for sure that the new EVO is WAY FASTER. By the way Mike21 his was an 05EVO VIII, Rally Red.
Old Oct 25, 2005 | 08:50 PM
Dyno_Man's Avatar
From: New York City...now residing in Fort Worth, Texas
here are sum stuff I heard between the STi n EVO
1. EVO's LSD is more electronical, STi is more mechanical....or so I heard
2. STi has weaker engine internals, EVO can hold up to 4-500 hp b4 internals must be swapped
3. STi's suspension is lower, EVO is more difficult to drift in
4. STi's are a lil more heavier than EVO's
thats sum stuff I heard, not sure if all is true tho...never driven either one so I wouldnt really kno 4 sure
Old Oct 27, 2005 | 01:31 PM
Mike21's Avatar
Hey mitsusales, do you know how to launch an evo, besides reving it up to 5k and dumping the clutch??
Old Oct 29, 2005 | 12:00 AM
ORIGINAL: Mike21
If you rev to 5k and dump it you will prob. bog it out and lose your clutch\TC rather quick in an 05 EVO they have a launch limiter that wont allow higher than 5k revs at launch unless it is removed. I have seen launches range from 5500-6500 RPMs and dont dump it you have to slip the clutch a little then when it starts to go just pin the gas and pop off the clutch. either way launching the car will abuse the clutch and TC so I wouldnt recomend doing it alot
Old Oct 29, 2005 | 12:02 AM
ORIGINAL: Dyno_Man
and to comment on this the EVO will out handle the STi but stock for stock an STi is faster than a VIII (VIIIpre 2005) The STi has a very weak motor the piston ringlands crack with only a few boltons as soon as it reaches arounf the 400HP mark they will crack. the EVO I have seen a dyno of 522WHP on the stock bottom end now anything after 500 they say is a good idea to build it up
Old Nov 1, 2005 | 06:37 PM
Mike21's Avatar
Thanks Bro, I'm gonna try launching later today.
Old Nov 1, 2005 | 08:10 PM
mitsusales's Avatar
mike21 the evoVIII have a more round torque curve so reving and feathering the clutch is your best way to launch. Now with the evoIX it has more of a flat torque curve and reaches its max torque at just 2500rpm, so trade that VIII in on a IX and you will be able to launch the lighter, and more responsive IX easier with less potential for TC and clutch problems.
Old Nov 1, 2005 | 08:12 PM
mitsusales's Avatar
pandalove182
Oct 29, 2008 08:06 AM
BEAT
Aug 21, 2008 08:56 PM
N/Teclipse
Jan 24, 2007 02:55 PM
