Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Bad catalytic converter
Old 02-05-2012 | 09:39 PM
wireman1995's Avatar
Default Bad catalytic converter
I have a 2006 eclipse 2.4 engine with 75k miles the check engine light is on and the code is bad catalytic converter i don't see how this part is bad and why is so dificult to find one, and expensive i also notice that there are 2 oxygen sensors,
will it help any if i replace them first ? in my supra we use a resistor so the sensor don't turn on the engine light because i don't have a catalytic converter, can i do the same in a 2006 eclipse ?
thank you
Old 02-07-2012 | 07:14 PM
2001 spyder on time's Avatar
in my 01 eclipse, i knocked out the catalitic converter, they make a sensor to eliminate the rear o2 sensor or bank 2 sensor, but the front o2 sensor is neccesary to control air fuel mixture, this is the sensor before the catalytic converter. i havent had any problems with the cat knocked out so far and i have 175k on my engine, with obx muffler and aem intake its got a nicer sound but is only a tempory fix for lack of money. the o2 sensors have ceramic inside and are fairly easily sheared from heat or use, they only work after reaching a certain temp also, so testing one isnt impossible but requires a torch.. hope any of this helped
jvmoney
07-30-2022 11:28 AM
steve7672
11-19-2006 06:51 PM
burnmyeyes
08-26-2006 12:21 PM
ryanp
05-21-2005 04:42 PM
FatalJRA
10-26-2004 02:46 PM
Quick Reply: Bad catalytic converter
