Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Bypass valve for intake?
Old Feb 26, 2007 | 03:03 PM
Kahuna's Avatar
Default Bypass valve for intake?
Just got a C.A.I. with the air filter close to the fender. I've been told i cannot run through puddles fast without hydrolocking my engine. My friend's teggy has a bypass valve that prevents this. Should i buy one or would it not really be a problem?
Old Feb 26, 2007 | 03:08 PM
estraw's Avatar
Default RE: Bypass valve for intake?
you can get a splash shield to put under the intake, then the only thing you would really have to worry about is submerging the intake
Old Feb 26, 2007 | 06:33 PM
the only way your gonna hydrolock from a CAI is submerging. Little splashes from puddles arnt gonna have an effect. Just stay out of really deep puddles and youll be fine
Old Apr 19, 2007 | 02:04 PM
2gEclipse96's Avatar
theEngineer is right a bypass valve for your intake is use less unless your going off roading and you submerge your intake in water i have a CAI on my eclipse i have went through puddles plenty of time you just can't go through the big ones... not tom mention the first day i put it on a went through an automatic car wash (i forgot about intake) well the filter was left on and it got soaked has soon as a took off the engine shut of........[:@]yeah i had the take the CAI off and spray quick starting fluid in the carberator (itis suppossed to evaporate all the water.... it started right up AEM's bypass vavle it a get quick scheme plum you would have to cut your intake in half... im not cutting my $250 intake in half
Old Apr 19, 2007 | 02:05 PM
Dusty Eclipse's Avatar
Where can one obtain said bypass valve?
Old Apr 19, 2007 | 02:06 PM
AEM'S website (they havea patent)i heard they do work wonder
s but only if you submerge the filter in water
Old Apr 19, 2007 | 02:08 PM
Ive already hydrolocked one motor in my 3g. Not doing it again. Its an Injen intake... will it still fit?
Old Apr 19, 2007 | 02:10 PM
http://www.sportcompactcarweb.com/te...lve/index.html i dunno they are around $50 it would be worth a shot but cutting your intake??? the above link did a great review you should check it out
firebuck
Oct 9, 2013 08:10 PM
fireboy153
Oct 7, 2013 04:46 PM
fireboy153
Feb 24, 2008 04:10 PM
mysterio2099
Feb 16, 2006 09:17 PM
outlancer
May 12, 2005 11:52 PM
