Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
Cat. Converter on aftermarket exhaust?
Old Dec 22, 2006 | 06:49 PM
kaiba408's Avatar
Default Cat. Converter on aftermarket exhaust?
Can a stock Cat. Converter be installed on an aftermarket exhaust system and still work as if its a stock exhaust system? Or does the whole exhaust system need to be replaced? Thanks.
Old Dec 22, 2006 | 07:10 PM
Default RE: Cat. Converter on aftermarket exhaust?
It would all depend on the exhaust system you are looking to purchase. It should say... "Cat-Delete" or something like "comes with a test pipe".
Most exhaust systems do allow the stock cat to be bolted up... i know mine did
Old Dec 23, 2006 | 03:23 PM
paintballproam's Avatar
I just put on a 3" magnaflow cat.
Old Dec 23, 2006 | 04:13 PM
sorry those high flow cats are total bull****. They do not do anything... well... unless you count 1hp (proven) as a justified increace. Nothin wrong with the stocker
Old Dec 23, 2006 | 06:09 PM
kaiba408's Avatar
Thanks a bunch...I was already planning on swapping the whole exhaust system. I just need the stock cat put on my car. I should definitely pass smog once I put it on. The first time I tested I barely failed in the 15 mph test. 2nd time, I changed my spark plugs to NGK's and I added Guaranteed to Pass Smog solution and followed the instructions on it. The day before the test I filled up my tank, next day I tested and the readings I barely passed in doubled to make it worse. Did the Guaranteed to Pass screw me over?
Old Dec 23, 2006 | 10:37 PM
any body i know who has used that stuff, made it worse. You really want an easy way to pass? Right before you get there, unplug an injector, then once u leave, plug it back it. I gaurentee u will pass. My auto teacher even said it works.lol.
Old Dec 23, 2006 | 10:46 PM
silvercoupe97's Avatar
I've got a magnaflow high flow cat. I can't say that it decreased any restrictions, but having a 3" turboback (to include 3" in/out on the cat) doesn't hurt either
saxonp4
Mar 25, 2008 06:29 AM
vytnom77
Oct 30, 2007 06:51 PM
motu1983
Sep 13, 2007 10:50 AM
motu1983
Aug 15, 2007 05:10 PM
mysterio2099
May 2, 2006 11:18 PM
