Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
How did this happen
Old Dec 30, 2007 | 02:21 PM
hiflyen's Avatar
Default How did this happen
I have a 95 GS and the head has a crack between the intake ports just before the intake valves on every cylnder. what could have caused this??? Is there any way to keep it from happening, or is it normal??
Old Dec 30, 2007 | 02:34 PM
dsm1990gsx's Avatar
Default RE: How did this happen
Post some pics of the cracks.
Old Dec 30, 2007 | 05:22 PM
_Adrian_'s Avatar
its a 420A..
lot of neons have problems with that..
poor design and i bet you the cracks are between the valve seats :P
also the failed head gaskets come from overtightening the head bolts and after a repated heat/cold cycle they stretch and loose the clamping load.
whe reinstalling the head i suggest a accurate torque wrench and follow the instructions to the smalles detail...
i replaced too many HG on neons
Old Dec 31, 2007 | 03:29 PM
hiflyen's Avatar
The head bolts were on so tight that i had to use a breaker bar just to get the head bolts off. So overtightening is the root cause huh. thanks I will unsure that I don't repeat that mistake.
Old Dec 31, 2007 | 04:25 PM
_Adrian_'s Avatar
also a good practice is to retorque the head at the first oil change as well.
havent had one fail just yet.
and my buddy's neon has 300K+ on the engine and no problems besides the cam/crank gremlins.
Old Jan 1, 2008 | 02:26 PM
hiflyen's Avatar
crank/cam gremilns??? can you expound a little on that? What happened?
Old Jan 1, 2008 | 09:50 PM
_Adrian_'s Avatar
they seem to fail with very lil stress.
not one of my buddies that take long trips with their 420A powered neons dont leave withoutthe folowing list:
crank and cam sensor, basic tool box (including a multimeter and a bosch or siemenstypenoid lite), a spare coil anda set of plugs.
that does not include the factory spare, jack and tire iron.
and im sure im missing something
Old Jan 15, 2008 | 09:32 PM
smithy's Avatar
any pics? it will make your query easier.
Old Jan 16, 2008 | 07:21 AM
GSXPimp's Avatar
ORIGINAL: _Adrian_
my old 420a GS Eclipse did half of this.....so oh yeah its true
nique
Aug 9, 2009 10:51 AM
BrunoBoy650
Oct 3, 2008 06:19 PM
Christian1
Mar 12, 2007 10:27 PM
5Tizzle
Jun 19, 2006 09:26 PM
BlackWidow99
Apr 16, 2004 04:57 PM
