whats the worst that could happen?
Old Jun 18, 2006 | 08:13 PM
5Tizzle's Avatar
Default whats the worst that could happen?
i got my trans off today, took the clutch off(very worn btw), and found that my problem was the throwout bearing had completely seized. it will not move at all. The flywheel looks to be in decent shape, and im gonna take it off and have it resurfaced, but im just wondering...whats the worst that could happen if i DONT resurface it, then put on a new clutch?
Old Jun 18, 2006 | 11:45 PM
magnet's Avatar
Default RE: whats the worst that could happen?
could wear your new clutch out fast. Also could be some shuttering when releasing the clutch. Better safe and just have it resurfaced like you are going to do.
Old Jun 19, 2006 | 01:22 AM
tattoogrif's Avatar
The worst that could happen depends on how bad your flywheel is. If it's still true (check it with a straight edge) and just glazed it'll just slip... If it's not true, it will wear out your new clutch disk faster, slip or shutter and could screw up your new TOB depending on how bad it is. I agree turn it while you can if there's any question.
Old Jun 19, 2006 | 09:26 PM
Sanguinius's Avatar
Definately. Turn it while you're in there. It's better to do it and know it's good than to not and always wonder until something breaks.
newoutlanderfan
Mar 3, 2014 03:54 PM
BrunoBoy650
Oct 3, 2008 06:19 PM
hiflyen
Jan 16, 2008 07:21 AM
tampabaymitsu
1st Generation
Oct 29, 2007 01:03 PM
Christian1
Mar 12, 2007 10:27 PM
