instaled a intake and my lancer is acting up help im going to cry
Make sure you installed the mass air sensor correctly, the right way round, and the harness is on right.
If all is okay... then remove the negative terminal of the battery for 30 secs, and then recoonect.
That should do it.
That should do it.
my 350z had the same problem and it was because i bought a k&n oiled air filter and it screwed up my injectors ... mass air flow sensor .. and oddly i had to get the ecu reprogrammed .. it feels like the car just throws random amount of power when it feels like it but now its fine ..
ORIGINAL: Ralliart3000
Evo_8
Oct 28, 2005 09:41 AM
