Intake, Headers and Exhaust Custom Exhaust? New Headers? Need Opinions on Intakes? Discuss making your ride breathe better here.
NOOB TUNER BOV and hardpipe kit screwed up something
Old Jul 20, 2007 | 08:49 AM
TSG59_Steve's Avatar
Default RE: NOOB TUNER BOV and hardpipe kit screwed up something
Just make a leak tester, you'll find all of the smaller leaks that way. Also might want to try some water and soap. The air will make the soap bubble.
Old Jul 20, 2007 | 10:02 AM
Dusty Eclipse's Avatar
Yea, its not that easy, ROn... its spooling halfway anyway.. Just make the leak tester.
Old Jul 20, 2007 | 01:11 PM
RCJr9186's Avatar
ORIGINAL: Sebba
Not that simple
true that 8 times out of 10 you won't hear a leak from just reving it up.... BUT if he has a big leak (like a missing gasket on the bov or something) than he will be able to hear it... it's something free and can't hurt to try.
Old Jul 20, 2007 | 08:05 PM
BurgRat's Avatar
ok i put the stock stuff back on and the car is still running crappy...................now what?????
Old Jul 20, 2007 | 08:48 PM
Im tellin you man boost leak... make a boost leak tester and find it
Old Jul 20, 2007 | 11:27 PM
BurgRat's Avatar
so once i took off the stock you think thats what caused the boost leak....so does a boost leak cause your car to miss too??? cuz it misses just sitting there idling. so where should i check for the boost leak at????
Old Jul 21, 2007 | 01:11 AM
Natedogg89's Avatar
well, if its missing then that means its plug and/or wires.....check for leaks from the turbo all the way through the side mount and up to the throttle body, the only way you can do this is if you make a boost leak tester. Do a search on DSM Tuners and you will come up with about 3-4 different testers yo can make. If you do your shopping right you can buy it for less that $10 and having a boost gauge comes in handy at this point because you need to know how much pressure your putting into the pipes....
Old Jul 21, 2007 | 05:05 AM
Yes... a big enough boost leak will cause you to miss.. and the car will idle like crap.
Old Jul 21, 2007 | 10:39 AM
BurgRat's Avatar
do i test each pipe after i put one on or do i put it all together then test the whole thing for a air leak.??
Old Jul 21, 2007 | 10:53 AM
Put everything on... and you attach the boost leak tester to the turbo. You remove the intake and put the boost leak tester in its place... obviously making sure that its tight
