`97 4d68t galant tacho+turbo problem
Old Nov 19, 2010 | 10:40 AM
ordii's Avatar
Default `97 4d68t galant tacho+turbo problem
Hey guys, I`m from Latvia and just registered here, because i have a problem and spent lot of time reading thru manuals n stuff, but cant find answer.
So the problem is - Mitsu Galant `97 (8gen) 2.0td - last weekend we got through a BIG puddle, the saloon was soaked and inside was like 1cm water level, i`m trying to dry it out, but it aint happening fast and after that i got this problem - the check engine light is on all the time, disconnecting battery doesnt help, i feel that turbo isn`t blowing, the car ir really..weak and the tachometer doesnt show anything. Speedo is fine.
And also noticed 1 strange thing - before i had some problems with starting - i had to hold the key and start it like for 10seconds, but now it starts up with almost half turn of the starter :wtf: even cold. strange for diesel.
Maybe someone can give me some hint where to look or what to do
Old Dec 15, 2010 | 09:42 PM
Vadimus's Avatar
It looks like your ECU (Engine Control Unit) has short-circuit or bad contact problem. Try to disconnect it and dry it out. I am not sure but it is either under passenger's seat, or behind the glove box.
Old Jan 7, 2011 | 02:03 PM
Sanguinius's Avatar
Spammer gone and will not be returning. Please keep things on topic just report the spam and either I or one of the others will take care of it. No need to threadjack.
Old Jan 17, 2011 | 03:46 AM
ordii's Avatar
changed timing belt and found the fault - engine crank angle sensor. md351408, fits only original..
when balancing shaft belt crashed i guess it hit that sensor and broke it...
dynamite1511@gmail.com
Nov 29, 2013 11:35 AM
opplocker
Aug 8, 2010 09:41 PM
jaybuk100
Sep 12, 2009 12:14 PM
oneill_59
Sep 25, 2006 03:59 AM
Deezy
Oct 8, 2004 01:09 AM
