Both high and low beams are on at the same time.
Old Jan 15, 2012 | 10:26 AM
asimons07's Avatar
Exclamation Both high and low beams are on at the same time.
2000 Mirage DE Coupe 1.5l 5 speed
I just bought this car about a week ago. My problem is that when i turn on the headlights the high and low beams come on. Flicking the dimmer switch doesnt always turn the high beams off. When I try to turn the high beams off the high beam indicator light doesnt go off but it does get a slight bit dimmer.
This is an intermittent problem so i dont think it could be a relay issue.
I checked all the fuses and cleaned/re-lubed the dimmer switch.
Any suggestions?
Windschief Hopkins
Aug 23, 2015 03:39 PM
unequal
Oct 18, 2012 09:45 PM
asimons07
Jan 23, 2012 02:49 PM
1steven
Apr 2, 2010 08:38 AM
