Flickering lights and Power
Old Dec 23, 2008 | 10:33 PM
Mr Grier's Avatar
Default Flickering lights and Power
While i drive, and my subs hit with bass, the lights in and out of my car flash and i occasionally loser power to my radio and most if not all of my car. it stops if i take my head unit off so the radio stays off, it seems like there could be a loose terminal on my battery, and there is maybe 8 things hooked up to the positive side of my battery. any input is welcomed.
Old Dec 24, 2008 | 08:51 AM
Mr Grier's Avatar
Default RE: Flickering lights and Power
well i just fixed the terminal and tightened everything down nicely, the bitch dont move now. =] but when the subs hit it still dims the gauges and headlights, but i have not yet driven it so im not sure if i lose power still, im hoping that solved my problems, maybe a new battery and/or alternator is in the near future?
Old Dec 24, 2008 | 09:49 AM
dsm1990gsx's Avatar
Check for loose grounds.
Old Dec 25, 2008 | 03:33 PM
Mr Grier's Avatar
i believe that i need a bass capacitor, i was told this by multiple sources, it will hook up to my subs and charge up power for when they hit. when the subs hit, the power from the capacitor will be sent to the subs when they need to hit, reliving the power drain on the battery from my subs hitting. i will reply again when i install the 2 12s with a bass capacitor.
Old Dec 29, 2008 | 11:12 PM
Mr Grier's Avatar
Well guys. IVe done much work to my system and its finally complete. I installed all new wiring, gold plated connecters, 2 pioneer 800 watt amps, and 2 directed audio 12s with a 1 farad capacitor. after hours of work, everything works great. all custom installed by myself, looks and works great, if soembody could make me a signature with this pic i have of it, that would be great.
Old Jan 2, 2009 | 10:35 AM
Lil Evo's Avatar
Sounds to me like you're in need of a big 3 upgrade. there's a nice write up on the12volt's forum on how to do it, and it will for sure help with the dimming, and also make the car run better from an electrical standpoint.
Mitsiboy
Oct 23, 2016 06:15 AM
MrGalantGuy
Nov 24, 2014 11:40 AM
Brian Yazzie
Jan 23, 2012 09:49 PM
GAngeldb
May 27, 2009 01:59 PM
Sup3rs
Oct 2, 2008 09:10 PM
