No sound from radio
Old Oct 8, 2008 | 09:00 PM
apemech's Avatar
Default No sound from radio
I just bought my Daughter an 01 Eclipse. When I got it it read code on radio, called Mitsubishi got the code. Now displays stations everything works but the sound. I have no owners manual, checked fuses but have no idea whitch is wictch. I found the amp but before pulling the seat I thought I would see if anyone has any ideas of something simple i'm overlooking.
Old Oct 15, 2008 | 09:18 PM
Lil Evo's Avatar
Default RE: No sound from radio
Chances are if the radio was restricted with the code, there was an aftermarket radio in there before you bought it, in which case the Infinity amplifier under the passenger seat has been bypassed. Depends on the quality of the installation, if the harness was hacked, you're probably better off going aftermarket. If you can simply plug it back in, you should have sound. Also, make sure that the round audio plug is in tact and plugged into both the factory radio and into the amp.
rosetex
Dec 8, 2008 06:14 PM
apemech
Oct 8, 2008 08:08 PM
5star
Oct 23, 2007 09:58 AM
amjr
Jul 25, 2007 02:14 PM
drg2007
Jun 29, 2007 10:23 PM
