problems hooking up amp
RE: dash light problem
Ok first off its not excactly the alternator because sure the alt sucks its not a high watt alt but if you put the right farad cap in it should put your power hits back to when it was stock for example i have 05 Lancer ES and if i have my radio turned up all the way i take power hits and thats stock no mods to system gettin a better alternator or putting a 1 or 2 farad in stock system could solve that but when i put my system in i plan on puttin at least a 2 farad cap in and i might put a higher watt alt in a better battery yes helps but a cap and alt will fix it but a new alt is more money then a battery so if a cap and battery fix it then great it also depends on what type of amp you are runnin i will be runnin a 1000watt 2ohm stable amp so my advice would be put a 2 farad cap in and see if it helps then replace battery and if you are still takin hits go with a new alt
tarmacES
09-29-2008 11:35 AM
50ul }{4ck3r
01-10-2007 09:37 PM
50ul }{4ck3r
01-07-2007 06:02 PM
