Fog Lights
Old May 9, 2006 | 04:23 PM
NubianSithLord's Avatar
Default Fog Lights
I just brought some fog lights but, I don't know how to install them.
Help please
Old May 9, 2006 | 04:36 PM
90eclipse_gs's Avatar
Default RE: Fog Lights
what make and year car need more info and dose it have a foglight relay
Old May 9, 2006 | 06:13 PM
3G Eclipse GS it still has the circles where the fog lights should be and the panel is were the switch should be. I would like to wire directly to the parking lights if possible.
Old May 9, 2006 | 06:51 PM
reactivelancer's Avatar
i just put fog lights in my 04 lancer es.. it's really simple.. the lights should have 2 wires coming out of them.. a power and a ground.
ground the wire to either the car chasis or to the negative side of the battery terminal.
as far as the power wire, you can do several diff things. i ran my power wire to the fuse that operates my head lights so when i turn my head lights on, they come on.. you can do that or run it to a switch so you can control when there on or whatever. simple wiring
Old May 9, 2006 | 08:35 PM
ya just do like reactivelancer said run a fused power wire and tap it in to ur parking lights and also put a switch like he said so there not on all the time
Old May 10, 2006 | 02:11 AM
05Wishitwasanevo's Avatar
Yeah i agree i helped install a buddies lights and we ran them to the chassis for ground and then we ran power up to dash for his switch and then to fuse for headlights
Jims M
May 1, 2011 07:52 AM
blueb16
Feb 27, 2011 01:33 PM
thecrowforever
Apr 14, 2008 02:38 AM
wookie
Aug 8, 2005 02:29 AM
hyperkiper11
Aug 25, 2004 12:04 AM
