radio
Old Oct 30, 2007 | 09:06 PM
itsme71190's Avatar
Default radio
ok the story....
i bought my 95eclipse in april. the guy before me put in a JVC headunit. i was going to replace it. i took it out and i noticed that he did a "custom wire job". he snipped off the harnest........
now my friend (also not to bright) sniped it again..... so now i have wires everywhere, no headunit.
where do i begin fixing this
Old Oct 30, 2007 | 09:11 PM
dsm1990gsx's Avatar
Default RE: radio
Find the factory harness connectors and try to match the wires lol, good luck.
Old Oct 30, 2007 | 09:39 PM
itsme71190's Avatar
Default RE: radio
lol..... tried. got another problem.
there all different colors........
Old Oct 30, 2007 | 09:53 PM
dsm1990gsx's Avatar
Default RE: radio
Lol well u better get out that wiring book
What is themodel eclipse you have,I can get you the factory wiring diagram for the radio.
Old Oct 31, 2007 | 06:59 AM
itsme71190's Avatar
Default RE: radio
95 gs
Old Nov 2, 2007 | 08:02 PM
Lil Evo's Avatar
Default RE: radio
go to best buy, circuit city, hh gregg, etc and pick up a 95+ Mitsubishi harness, and a reverse harness that will fit it. Wire in the reverse harness to what's been mutilated, the other to the wiring that comes with your new radio. Wire colors on the reverse harness should be as follows:
Yellow 12v Constant
Red 12v Accessory
Black Ground (my harness did not have a ground, so if this is the case, you can go to any of the metal braces behind the dash. Just make sure it's securley fastened and that there is no paint, just bare metal.)
White Front Left (+)
Whte/Black Front Left (-)
Grey Front Right (+)
Grey/Blcak Front Right (-)
Green Rear Left (+)
Green/Black Rear Left (-)
Purple Rear Right (+)
Purple/Black Rear Right (-)
Blue/White 12v Acc Amp turn on
Orange & Illumination wires are Orange and Orange/White, but unless you've got a deck with a built in night time dimmer, you won't need these.
Old Nov 3, 2007 | 07:34 AM
itsme71190's Avatar
Default RE: radio
ok. thanks. ill work on it tomarrow and let u no how it goes.
thanks
Old Nov 9, 2007 | 12:27 AM
sk8dudety's Avatar
Default RE: radio
how'd that work out for you? did you get it figured out yet?
Old Nov 10, 2007 | 10:11 PM
itsme71190's Avatar
Default RE: radio
i got all the wres hooked up. but i got a short........
got to rewire it.
Old Nov 16, 2007 | 11:31 AM
Lil Evo's Avatar
Default RE: radio
take a meter to it, check your constant and accessory lines. if it's not those, a speaker lead is grounding out. easiest solution is to run new wires.
antron
Nov 23, 2012 01:05 PM
rosetex
Dec 8, 2008 06:14 PM
MonSport
Feb 21, 2004 05:59 PM
bigbubbles07
Dec 15, 2003 12:33 PM
Gana
Mar 9, 2003 08:22 PM
