Radio shorting?
Old May 30, 2020 | 04:28 PM
deftone39's Avatar
Default Radio shorting?
Hello I have a 2014 Mitsubishi Outlander Sport with a factory unit, navigation system.
So I need some help....My car radio stops playing music @ level 27 (it's max level is 45). The GPS still functions, etc.
At first I suspected that my rear passenger speaker had blown and was somehow shorting out the radio, so I removed it. That did not fix the problem.
I then thought perhaps it was the amp fuse for the radio. I replaced that fuse. Same issue.
Replaced the actual radio fuse in car cabin. Same issue follows.
I then noticed if I unlocked my doors the radio kicks back in ( I know wtf). However, if I turn the radio up past 27 it fizzles out and I have to hit the door unlock button to continue to make the radio portion play music.
Just for ****s and giggles I replaced the fuse for the door lock. Radio issue follows.
Anyone have any ideas? Grounding? I don't know at this point. It's a long drive to work, and would like to use my radio.
Old Aug 3, 2021 | 05:35 PM
Bb11's Avatar
Did you fix it? Cheers
Old Aug 3, 2021 | 05:43 PM
deftone39's Avatar
Default Yes
Turned out the internal amp on the radio blew, oddly cause a short in the electrical system. I ended up replace the radio and everything returned to normal.
keigelbach01
Feb 14, 2022 05:41 AM
cybergoogle
Apr 6, 2009 10:34 AM
johneast
Oct 31, 2008 02:55 PM
susie22
Nov 19, 2007 09:16 PM
cornbread2
Jun 24, 2007 05:11 PM
