Turbo ECU on no turbo car
Old Dec 22, 2007 | 11:38 PM
silvercoupe97's Avatar
Default RE: Turbo ECU on no turbo car
Sorry bro, but you can't just throw in a turbo ECU in an n/a car. The fuel maps in a turbo ECU will flood your GS if it even plugs in and Dusty stated, you'll have to consider the MAF, you'll need an MDP sensor on the intake manifold...blah, blah.
Old Dec 24, 2007 | 05:41 PM
lhausi2's Avatar
yeah just leave the non turbo ecu in there and get either dsm link or at least an afc, then you should be all set
Old Dec 24, 2007 | 09:02 PM
Dusty Eclipse's Avatar
DSMLINK
Old Dec 24, 2007 | 09:36 PM
lhausi2's Avatar
oh yeah i'd deff pick dsmlink anyday over an afc, if i had the money that is,lol
Old Dec 25, 2007 | 08:21 AM
dsm1990gsx's Avatar
You can run a turbo ecu ona non-turbo you just have to add the wiring for the knock sensor , maf and a few other things. Look on vfaq.com, they have a copy of the pinouts for turbo/nonturbo ecu's. Hope that helps.
Old Dec 26, 2007 | 06:13 PM
ORIGINAL: dsm1990gsx
...but what's the use? I'm not doggin' ya, but that's a lot of work just to add a turbo onto a non-turbo motor.
A turbo ECU has a higher threshold than a non-turbo motor can even handle...think output. Why not build up the motor correctly and use a stand-alone ECU or stick with the stock motor and ECU and then add a turbo and a piggyback computer? Same output, less headache.
Old Dec 27, 2007 | 06:51 AM
dsm1990gsx's Avatar
ORIGINAL: silvercoupe97
Yeah I know what your saying but its really not that hard to do to convert the wiring harness to make it work.And if he did, you could run 9-10 psiw/ supporting mods on a n/a engine.
You could also get a same year turbo wiring harness for next to nothing at a junk yard and it would be a drop in to the non turbo w/ no wire splicing or anything.
Old Jan 18, 2008 | 11:07 AM
Clipse1's Avatar
Thanks guys... Does anybody know where I can get dsm link? I've been looking for it and cant find it....
Old Jan 18, 2008 | 01:12 PM
dsm1990gsx's Avatar
ebaymotors.com, pretty much any dsm performance partssupplier.
Old Jan 18, 2008 | 04:24 PM
you cant use dsm link on a gs ecu. I would just go with an SAFC
