windows go down but dont go up?
Old Mar 30, 2008 | 01:19 AM
feonixwolf's Avatar
Default windows go down but dont go up?
hey all,i have a 97 gst spyder,when i drop the top all 4 windows automaticlygo down as well,but will not go back up.when i got the the car there was a ton of extra parts,nuts,bolts,2 extra heads,1 extra valve cover,extra intake,2 extra turbo exhaste manafolds.BUT there was also a door actuator in the boxes.i have been from 1 end to the other trying to find either an empty plug that the door acuator fits or a actuator that is shot.i checked every fuse,every fuse link,every relay,and the only way i was able to get them up was to run a wire from the battery to the plug and try to power them and get them up befor it rained.it sucked but it worked.the power locks are not working either.any help at all?
Old Mar 30, 2008 | 09:58 PM
itsme71190's Avatar
Default RE: windows go down but dont go up?
maybe a relay???
Old Mar 30, 2008 | 10:01 PM
feonixwolf's Avatar
checked all relays,was wandering if there is a window control box somewhere.
Old Mar 30, 2008 | 10:02 PM
itsme71190's Avatar
hmmmm....
check the wiring on the window motor
Old Mar 30, 2008 | 11:47 PM
feonixwolf's Avatar
all checked,if i run a jumper from the battery i can make them go back up,maybe the door switches themselves?not sure,going to have to go over it all one more time,maybe i missed something.thanks for the input by the way,ever idea helps.
Old Mar 31, 2008 | 10:27 AM
dsm1990gsx's Avatar
Well if you ran a jumper and the motor moves up, your probably not getting any power from the window swich. Ohm the wire from the motor to the switch and see if its good. Sounds like you have a broken wire between those 2 points.
Old Mar 31, 2008 | 02:35 PM
feonixwolf's Avatar
on all 4 windows?they do go down when the top goes down.
Old Apr 2, 2008 | 09:48 AM
dsm1990gsx's Avatar
ORIGINAL: feonixwolf
Oh sry I missed that part. Check the master window switch, see if there is continuity @ the switch w/ the windows going up.
Old Apr 2, 2008 | 12:45 PM
feonixwolf's Avatar
fixed,lose wire at my battery termanal
bassadict69
May 13, 2014 01:32 PM
gretzky
4th Generation
Mar 22, 2011 05:31 PM
nukn_futs_demit
Mar 19, 2006 03:38 AM
pinkglow
Feb 1, 2006 09:22 AM
DragonRacerX666
Apr 20, 2005 12:14 AM
