Internal Lounge Chat about beefing up your insides here.
blown motor
Old Apr 28, 2007 | 08:47 PM
jdm91hf's Avatar
Default blown motor
ok guys blown engine haha 4g63t what would have caused this?i got it this way,the number 1 is broken would the oil pump be the cause? it was full of oil and antifreeze, would it have been over revved? im rebuilding another engine for it but i need the oil pump out of this one, a new one up here is $300 buxx to get one.
the engine is the 6 bolt 92 gsx. any help is welcome thanks!!
Old Apr 28, 2007 | 08:53 PM
Default RE: blown motor
the new engine or the old engine or both are 6 bolts? is sounds like the motor isnt blown oil and antifreeze in the cyl usually means the headgasket let go
Old May 5, 2007 | 01:21 AM
jdm91hf's Avatar
it is blown, number 1,2,3 cyl be down while number 4 be up and it wont crank over far at all ( by hand of course) the rod is broke, both blocks are 6 bolts. it wasnt beat to death it has 123,000 miles on it.
what worries me though is that i need the oil pump off the blown one for the good one, a new oil pump up here cost me over 300 buxx for it and i cant afford that right now. sorry for the confusion the crank case was full of oil and the radiator was full of antifreeze.
Old May 5, 2007 | 12:18 PM
i agree with emonz. it does sound to me like a head gasket. Have you done a leakdown test to see if it is the engine? Have you pulled to oil pan to check for shavings or anything?
Old May 5, 2007 | 03:54 PM
jdm91hf's Avatar
pulled the pan and the rod is broke, i think the last owner over revved it one to many times, theres no antifreeze or oil in the cylinder,plus when number 1,2,3 cylinders are down dont that mean something broke?, when number 4 is up?
jjm525
1st Generation
Aug 6, 2007 07:29 PM
SilverCel
Oct 18, 2006 11:38 AM
radrob2
Mar 23, 2006 01:55 PM
theycalmewiteman
Feb 25, 2006 02:45 PM
promxz24
Oct 18, 2004 12:11 AM
