Internal Lounge Chat about beefing up your insides here.
cam timing
Old May 25, 2011 | 03:47 PM
D504x4's Avatar
Exclamation cam timing
I just did a head gasket and this is my first sohc. How do you get the cam timing right when putting the timing chain back on. Its an 89 2.6L. There is a mark on the cam gear, is there one on the crank gear too? Id rather not pull the whole front of the motor apart if i dont have to. Any advice would be appreciated asap. Im driving a 65 pontiac until this is fixed so the sooner the better haha
Old May 25, 2011 | 09:02 PM
you need to first figure out where the marks are on the head/block. Ussually there are marks as to where the cam gears should be pointing at (or they may just be pointing at each other) and then the mark on the crank pulley should line up with a mark on the block (most of the time its on the timing cover).
But i would suggest getting a manual for that car and determine exactly how they should be lined up
jallen28144
Sep 7, 2013 12:40 PM
8000RPMS
Aug 30, 2007 05:49 AM
kaos8704
Nov 9, 2005 05:00 PM
strummin
Sep 8, 2005 02:56 PM
Black98
Apr 16, 2005 07:23 PM
