Internal Lounge Chat about beefing up your insides here.
I THINK ITS CRANKWALK!!!!!!!!
Old Mar 6, 2007 | 04:37 PM
RCJr9186's Avatar
Default RE: I THINK ITS CRANKWALK!!!!!!!!
yeai know that but he ddin't say anything about turns so it just sounds to me like low fluid or a leak somewhere.
Old Mar 7, 2007 | 01:49 AM
tx2u's Avatar
Ok, I've been beating my head on this crankwalk and pedal sticking to the floor issue. Sorry for the ignorance, it's just that I haven't experienced it with the 3 turbo dsm's that I've owned. Below is the breakdown of how our clutch system system works:
Hydraulic clutch system:
-press the clutch pedal; thus creating pressure which in turns push the piston inside the clutch slave cylinder.
-piston extends out the clutch slave cylinder rod which then pushes on the release fork.
-release fork presses the throw-out bearing in the middle of the diaphragm spring; which pulls the pressure plate away from clutch disc.
With that being said, you'd have to have a huge amount of endplay (max tolerance is .0071", correct me if I'm wrong) for the diaphragm springs to not push the throw-out bearing back and reverse the procedure above. I don't know what the exact travel is for the throw-out bearing when the release fork is fully engaged by the stock clutch slave rod so I can't get estimate what the "point of no contact" is (which is why people are having a hard time shifting when experiencing crankwalk). I have read posts of people having as much as 10mm of end play; that's .39". I think it's more than just the bearing that is being chewed at that point.
As for the left hand turns, that's a whole different story and I don't even want to speculate on it [&o]
natewesselink
Feb 28, 2007 08:48 PM
ktulu1984
Aug 24, 2006 01:00 PM
ktulu1984
Aug 24, 2006 12:42 PM
BrunoBoy650
1st Generation
25
Mar 6, 2006 02:08 AM
reallyaLS1chick
Apr 21, 2004 02:15 PM
