3000GT Clutch Slave Cylinder
I am new to the forum; but could not find any current posts on my specifics. Just bought my son his first car, a 1998 3000GT. We already have a failed clutch, and all my previous experience is with mechanical clutches - not hydraulic. The pedal sank to the floor, not to return, after about one week of noticing a gradual fade. There does not seem to be leakage inside the vehicle from the master cylinder, so I am suspecting the slave - also, noting some other posts about slave cylinder problems. So, there looks like no convenient way to access this cylinder, and Haynes does not publish a manual for it. Is the recommended access method from the top - removing the air intake ducts, or should I be trying to get the car up high enough to work from the bottom?
Thanks for any hints here.
Kevin
Kevin
Kevin
Kevin
Feel free to call me with any questions, I run a shop specializing in these, 301-991-6501,
Seth
Seth,
So, it turned out that the problem was just properly bleeding the clutch. I was bleeding with the bleeder valve; however, given the amount of air that had been introduced to the lines, we had to pull a vacuum to get the air out of some of the high spots.
Thanks!
Kevin
Thanks!
Kevin
micahman
03-03-2006 10:52 PM
